Possibility to export assets as .eps
olga
To enhance the workflow between Figma and After Effects, it would be great to be able to save Figma Assets as .eps files since After Effects does not support .svg, which cause an extra work step - firstly saving .svgs and converting them as .eps or .ai.
I have tried using AEUX Plugin as well to bring the Figma Assets into After Effects. It is great for small scenes. However, for the bigger compositions, it does not yet work properly - as a result Figma either crashes, or there are too many precomps produced in After Effects, which is not the most optimal way to animate objects.
Therefore, to enhance the workflow between Figma and After Effects and still have the possibility to manually arrange scenes in After Effects, it would be great to have an opportunity to export assets as .eps. This will save an extra work step of converting .svg files.
Thanks a lot!
  • 4710 replies
  • May 11, 2021
As a workaround, you can import SVG into Illustrator and then export a file from there to AE.
olga
  • May 12, 2021
Dear Gleb,
Thanks for your reply. You see that is exactly what I was doing, but the problem is - it slows down a process quite a bit.
If I export 150 assets and have to manually re-save them as .ai - that takes way more time than just exporting .eps files from Figma directly. Would be a great help & would speed up the workflow and make it more efficient.
Best,
Olga
  • 4710 replies
  • May 12, 2021
You can batch convert SVG to EPS or AI using various methods: from online services to using Illustrator actions or scripts.
Melissa_McArthur1
Crazy that one must have Adobe Illustrator access to do this. A beauty of Figma was to avoid needing the Adobe Creative Suite licence.
  • 4710 replies
  • February 25, 2023
Figma is a UI design tool. EPS has nothing to do with UI design. Plus there are a lot of other methods to convert SVG to EPS other than Illustrator as I mentioned.
Ehsan_Tabatabaei
As of when was it purelyUI; you can even export code and the sanitise/change to fit your project needs. I say this as a sr web developer.
I concur with others: Possibility to export assets as this comment states: Possibility to export assets as .eps - #6 by Gleb
It is insulting to provide such a vain response. It addresses nothing but you managed to make a murky, nebulas, unrelated response.
I have not used it in 7 months and this is still an issue?
Gleb I will be chatting with Figma soon if you are still employed. Unbelievable.
@Melissa_McArthur1
