Placed images not exporting in .svg
jamie_sigler
Hi all. I have a couple of frames that have placed image in.
I want to export as .svg format.
I can see the image in the preview and on the preview of the .svg. But when I open the .svg in adobe illustrator the image isnt there and just should a blank box…
Any ideas? It worked fine in sketch before.
ThomasHallgren
SVG does not do a good job supporting images. Try adding the image in Illustrator.
ak12
  • July 4, 2024
If you encounter this problem today, will you get the same answer, or is there a new way?
Gayani_S
  • 2197 replies
  • July 24, 2024
Hey @ak12, thank you for reaching out!
I can create support ticket on your behalf so our support team can take a look at your file. Before that can you answer me the following question:
Are you having trouble opening up the SVG files in chrome or another application?
Gayani
ak12
  • July 25, 2024
@Gayani_S, Thanks for reaching out to me too.
Yes. The SVG files isn’t trouble opens and works in other applications.
photoshop and chrome.
Then I looked again and realized that some computers were opening the file and some were not.
Gayani_S
  • 2197 replies
  • July 26, 2024
Thanks for the information @ak12, can you give me an examples on what devices the SVG is opening correctly and and on what devices it is not?
I would need this information to double check internally with the team.
Thank you in advance!
really nice, the question is from 2022, and 2 years later it’s still here. Ok I have the same problem, I export the frame with embed image in Figma to svg, open it in AI and the image is gone.
About a month ago I must use export with pdf, and the image is still show up in AI. But now it’s gone too with pdf export.
Please check what is happen
Gayani_S
  • 2197 replies
  • August 2, 2024
Hey @Truong_Tran, I think your sentiment is valid when seeing that this issue is still ongoing, hope to see this resolved soon too!
I’ve created a support ticket on your behalf, so our team can investigate further on this. Your ticket number is #1083031, for reference.
Please do share a screen recording with the team, so they can investigate further.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Gayani
Thao_Le1
  • 5 replies
  • August 13, 2024
I’m encountering the same problem. Any Figma frames containing images result in missing images after exporting as SVG and importing into Adobe Illustrator. It’s frustrated situation.
Gayani_S
  • 2197 replies
  • August 13, 2024
Hey @Thao_Le1, thank you for reaching out!
Can you please share a video recording of the issue you’re encountering with a description/explanation? I’d like to see if you are able to export the SVG successfully in Figma and only have issues when importing the SVG in Adobe Illustrator.
Rob29
  • October 29, 2024
Im having this problem as well. Any possible solution coming?
Gayani_S
  • 2197 replies
  • October 29, 2024
Hi @Rob29, thank you for reaching out!
I took a look at the support ticket I filed for the previous user experiencing a similar issue, and it appears they haven’t had a chance to follow up with our support team yet. In the meantime, to help our team troubleshoot effectively for you, could you please share a video recording of the issue? Showing the full Figma window, with the properties and layers panels visible, and expanding any relevant layers you’re having trouble with, would be really helpful. This allows our team to try reproducing the behavior in their own files.
Could you also provide a direct link to the file and invite support-share@figma.com with “can edit” permission? Users with @figma.com emails won’t count toward your billing.
Lastly, are you able to export the SVG successfully within Figma, but then encounter issues when importing it into Adobe Illustrator? Any additional context like this can help us get to the root of the problem.
Thank you again for your help, and we’ll do our best to get this sorted out for you!
Rob29
  • October 29, 2024
Sure, until I get a chance to do all that, here’s some additional info: I recreated the graphic in Adobe Illustrator and exported as SVG from there, and had the exact same problem occur where the embedded image would vanish from the SVG while all vector elements remained. So in fact, perhaps the issue is with the SVG format itself? It’s very bizzare as sometimes the image will show in the thumbnail (when viewed in the Finder - on Mac) and sometimes it will not, the same file, without resaving it or anything, just looking at it at different times.
Gayani_S
  • 2197 replies
  • October 30, 2024
Hi @Rob29, thank you for sharing those extra details—it really does sound like the SVG format might be at the root of this issue, especially with the inconsistent display of embedded images.
Just to narrow things down further, is this happening in both the Figma desktop app and the browser?
Christina_Maybin
I’m having this issue too, trying to export SVG files with images with no luck–the images don’t show up when I open it up in Illustrator. Is there a workaround for this?
Gayani_S
  • 2197 replies
  • November 13, 2024
Hey @Christina_Maybin, thank you for reaching out!
I’m sorry to hear you’re having trouble with exporting SVGs with images!
Could you let me know if this only happens when opening the SVG in Illustrator, or if you’ve tried viewing it in other tools as well? Sometimes different programs handle SVGs uniquely, which could help narrow it down.
If possible, could you also share a screen recording of the issue? Including the full Figma window with properties and layers panels visible and relevant layers expanded would be ideal.
Thanks in advance!
Christina_Maybin
I’ve tried opening the files in Illustrator and InDesign, and the non-vector image assets are still missing.
Is there any way I can send privately? The file can’t be shared publicly. I submitted a support ticket for this issue on 11/11 and have not received a response but would be happy to work with them privately.
Gayani_S
  • 2197 replies
  • November 21, 2024
Hi @Christina_Maybin, thanks for letting us know. I’ve found your support ticket (#1173422), and I’m really sorry that you haven’t heard back from the team yet.
We’re experiencing a higher volume of inquiries right now, which has caused some delays.
Please go ahead and share the file privately with the support team; they’ll be able to assist further.
I’ve escalated your ticket to help ensure you get a response as soon as possible.
Let me know if there’s anything else I can do to help in the meantime!
Wonder_NG
  • November 27, 2024
Hello, I’ve experienced the same problem for like 3 days. I had to make a presentation of the interface, in mockups, and for quality, I need svg files but images wasn’t shown neither in Illustrator or Photoshop. To make it short, after testing many different approaches, I end up exporting Figma assets as PDF then placing them in photoshop, which worked as the quality remain as svg’s quality plus, the pictures aren’t lost.
Nahdej Williams
Hi there. Just following  up on this 😊. Have there been any updates? Or is there something that I can do in order to have the images export with an svg format?
I would prefer not to have to do it in multiple steps. I am in need of editable text files for my designs which I why export as svg. Problem is I have a team that needs to be able to edit in Illustrator and the images still aren’t showing up.
Tanvi Chunekar
Hi, I’m also facing this issue. Any solutions to this?!
Eli Nikolova
Hi, we have the same issue.
lucalucaluca
Same issue, exporting svg from figma, it shows perfectly in chrome or opening it back in figma. However opening it both in photoshop and illustrator shows everything except the included images.
Gayani_S
  • 2197 replies
  • July 11, 2025
Hey everyone! I’ve followed up on the support ticket I’ve created for the community member who previously flagged this.
The team recommends as a workaround, to export the design as a PDF instead, which you can then open and resize in Photoshop without the same issues. It might also be worth reaching out to Adobe to see if they have additional insights or suggestions.
That said, if you’re experiencing this and would like our support team to take a closer look at your specific case, feel free to reach out to us directly via this form.
We really appreciate your patience and the time you’ve taken to report this!
