Paragraph spacing issue
Here is what I’m doing:
Use the type tool and enter some text
Select text and size it
Set paragraph spacing
I expect that changing paragraph spacing would change the paragraph spacing but it does nothing. I changed fonts but just got the same result. Scratching my head.
Best answer by Kevin49
Restarted and it works now.
Thanks!
Bryce_Driesenga
You definitely have multiple paragraphs/hard returns? And you’re not adjusting line height instead?
  • September 1, 2023
AS you can see Paragraph spacing is 0 but there is a tone of space in between lines. I can increase the space but cannot make it smaller than this for any font.
  • September 1, 2023
Thanks!
Bryce_Driesenga
In that screenshot, you had your line height at 35.
Shruti5
  • May 19, 2024
Hi, i am facing the same issue even after restarting Figma, please help!!
Bas_Schellekens
Same problem here
Celine_
  • 3751 replies
  • May 21, 2024
Hi there! Can you try to clear out your cache if it only happens on desktop app?
Does your paragraph spacing breaks if you mix text styles in a single text block? If so, please check this thread where others encounter similar issues: Paragraph spacing settings break when mixing styles in single text block - #11 by ScoJo
If this doesn’t help, I’d recommend you to share a quick video recording and a copy of your file so the team try to replicate and investigate further: here.
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as an Editor, so we can take a closer look.
