On hover animation content inside buttons moves slighty
Alexandru_Adam
I have some buttons that have a hover effect and in the prototype there is slight movement of the content.
  • I checked the position of the content to be the same in both instances (default and hovered) in regards to the margins and in between items
  • I applied a “while hovering” interaction with instant animation
This also seems to happen in between separate screens of a prototype for text in a header component that doesn’t have animation applied or any other interaction.
Screen Recording 2022-10-19 at 14.12.55
Anyone has any idea?
Abhay_Chandra
Same issue here. Seems an issue with the prototype mode. The movement seems to be happening at random, varying in each launch of the prototype window. I absolutely hate it.
Maximiliano_Gomez
Same here. Have you found a solution to this?
Todd11
  • March 1, 2024
I’ll chime in and say this is extremely annoying and I can’t believe it’s not a bigger issue worth solving.
Celine_
  • March 4, 2024
Hey all,
Sorry to hear this is happening! This seems buggy. I can’t reproduce on my end. Is it happening on desktop app, browser or both?
As a first workaround, I’d suggest you to clear out the cache to see if this can help.
Mac
Use the Terminal app to clear the cache.
  1. Quit the Figma desktop app.
  2. Open the Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma/"{Desktop,DesktopProfile}
  3. Try opening the Figma desktop app again.
Windows
Run a command line from the Start menu.
  1. Close the Figma desktop app.
  2. Open the Start menu and paste the %APPDATA%\\Figma command. Press the Enter key to submit.
  3. In the window, delete the DesktopProfile folder.
  4. Launch the Figma desktop app again.
If this doesn’t help, I would like our support team to investigate further. Please reach out to them by filling this form here.
Be sure to use your Figma account email, your GIF, include a link to the file, and share it with support-share@figma.com, so we can take a closer look. Thank you!
This solution didn’t resolve the issue I’m experiencing
Celine_
  • March 27, 2024
Hey Jamie,
Sorry to hear you are having issues! If this workaround doesn’t help, please reach out directly to he support team: here.
Be sure to use your Figma account email, include a quick video recording when you encounter the issue, link to the file, and share it with support-share@figma.com, so we can try to replicate your issue and investigate further.
Hey guys! I have the same annoying issue and the only solution that helps me is to open my prototype in the browser version of Figma. So this problem is specific just for desktop application. My OS is Windows, web browser - Firefox.
Ahmad_Jamali
Does anybody know if this issue still exists?
What’s the solution Please?
Alex184
  • May 14, 2024
I am also having this issue. Everything slightly shifts when I hover over any of my components.
Ric_Mark
the only fix I know is you need to add a border but just make it match the fill color if you want to make it look like borderless.
Rob20
  • September 5, 2024
Not sure whether you’re Grouping or Framing elements - but I found Framing instead of Grouping elements solved my problem.
Nati_Tobon
The same thing happens to me here, however, I have noticed that when opening the prototype in the presentation option it works fine. It is in the preview option, which has this little movement.
Colibra Labs
In my case, this bug is happening in the web version of Figma, with 'While hovering' applied between two variants of a card. When I hover over it, the card should only change color, but it moves approximately 1px up and to the left. My browser is Chrome for Windows.
Marko Milosavljevic
For me this happens in Figma App, in all of the projects. While hovering effect moves the buttons by pixel.
Sasha S
  • July 10, 2025
Hi there, i was looking for a solution & i will share something that works for me today..
Well, just to give some of context. I was creating a card component with hover effects on Figma. Then i use that component inside a frame with auto-layout, and when prototyping the whole frames moves with no sense.
The solution: I had to ungroup all the frame and the auto-layout where this component was. And now the prototype runs like it should.
So… it looks like when is inside of an auto-layout or frame always do not work properly the hover effects on prototyping. And of course that is a problem, because doesn’t let you to use it inside a main frame or auto-layout …. :/
I hope that this can work for you too 🤗
