O que é image resized?
Matheus_Pimentel
Does it affect the image quality or something? I didn’t notice it before, but it seems that after the UI3 update it started to appear every time an image is inserted into the Figma.
Best answer by djv
Hey @Matheus_Pimentel, thanks for reaching out and sorry for the confusion!
This is not a new feature. Figma has a built in size limit for images of 4000 pixels, so any image larger in either height or width will be down scaled to fit.
As a workaround, you can either make your image smaller or crop the image into parts and put the image back together. If that’s too time consuming, you can also use the Insert Big Image plugin from the community.
  • 4864 replies
  • August 6, 2024
Matheus_Pimentel
Muito obrigado pela resposta!
