Numerous line breaks when pasting text from wherever it is
Hey! Ive never had this problem before, but since today it has started to add numerous amount of line breaks when i copy/paste text from different sources.
Ive also noticed that it adds only 2 line breaks when copying from powerpoint or pdf docs.
It is getting impossible to work since i have to do a lot of copy/paste activity. Please, help!
Gayani_S
  • 2168 replies
  • January 10, 2024
Hey Eldar, could you tell me what steps you’ve taken to reproduce this on my end? Have you imported this from google docs?
J_Siciliano
Also starts happening to Mac. We copy from Word. This needs an urgent fix.
J_Siciliano
Hi Gayani,
Is anyone looking into this issue? Thank you!
  • January 11, 2024
I am just copying text from Microsoft Doc (ctrl+c/ctrl+v) and it happens (additional numerous of line breaks above and below the text). And as i mentioned, copying from other sources adds 2 additional line breaks to any copied text.
It hadnt been happening for the ~year since I use Figma in my work, ive never encounter that problem doing pretty the same things.
I also tried pasting with other combination of keys: ctrl+shift+v - it does not happen to add line breaks, but it is impossibly inconvenient when you have so much text to copy and paste.
Thanks.
  • January 11, 2024
Same thing started to happen to me today. When copying from Word into a text field in FigJam, 14 line breaks above the text is added and 4 below.
Am also on a Mac.
J_Siciliano
Found a workaround. Try and see if it works for you guys too.
Try ctrl+shift+cmd V when pasting.
This paste the text without line breaks for me.
  • January 12, 2024
I can’t even paste it with that combo unfortunately. Maybe I’m doing something wrong, but I’m copying the text from word (cmd+c) and then I try to paste it in a text field in FigJam with ctrl+shift+cmd+v and it does not give me any text at all 🫠
Добрый день, у вас получилось решить эту проблему, у меня такая же проблема, это какое-то мучение
Gayani_S
  • 2168 replies
  • January 15, 2024
Hey everyone, I am not able to reproduce this bug on my end. Please reach out to our support team. They can investigate further why this is happening.
  • January 18, 2024
Experiencing the same issue my end since the start of the year. When pasting copy from Word (only) does this happen and have tried other text formatting software. Cmd+Shft+V works however removes any formatting I want to keep such as superscripts.
Gayani_S
  • 2168 replies
  • January 22, 2024
Apologies! We created a bug report and the team worked on the fix. If you’re still experiencing this issue please confirm this for me. I can create a bug support ticket in your behalf.
Matt104
  • October 21, 2024
HACK THAT WORKS! – “Remove Formatting” (Command + \ in Mac) tool in Gmail. I still have the problem of the line breaking in the middle of words when I paste text from different sources (Copilot) into Figma. I tried making it plain text in Text Edit first, but that didn’t even work. What DOES work is pasting it into Gmail and using the tool “Remove Formatting” (Command \ on Mac). Then, when I paste it into Figma, there is no issue.
