Nested accordions not expanding accordingly
  • September 10, 2023
  • 335 views
Hi, I am trying to nest 2 accordion components within each other. I have both of them created as separate components with the height set to hug contents. Individually, the container resizes accordingly during prototype testing. When nested however, the outer container does not resize with the contents inside. Any suggestions on how to fix this would be appreciated! Thanks in advance!
Video of issue:
drive.google.com
katrina.smith
For anyone that stumbles on this post. I had the same issue and Pavlo_Kiselov this post helped me fix my nested accordion issu
The issue is how and where you place the accordion interactions.  Don’t put them on the component itself --- put it on the header of the accordion.  You may have to use the layers panel to control layer selection when applying the interactions vs. using the interaction buttons on the component.  Hope this helps someone .
