Navigation with arrows in preview with starting point
  • July 12, 2024
  • 358 views
Vojtech_Lacina
Hi, there is probably a feature request related to this topic → Prototype arrow key navigation
As mentioned in docs, there are two types of Prototype Preview:
  1. With starting point
  2. Without starting point
The problem is, that sometimes I want to present the design like a prototype (with a starting point) and sometimes without → Navigate between scenes with the arrow keys [<-] [->] to spot the difference, etc.
Now you have to delete all prototype flows to navigate between screens with arrow keys which is really time consuming, especially when you have a lot of prototype connections.
Proposal
Add a new option to the Preview settings:
  • Use arrow keys for navigation
Which
  1. Will be disabled, when prototype has no starting point.
  2. May be enabled, when prototype has starting point
Another option is to have it enabled depending from which panel the user run the Preview:
  1. Design → let’s use the arrows keys for screen navigation
  2. Prototype → let’s use the arrow keys for history navigation
From the docs:
Prototypes with a flow starting point
If your prototype has a starting point, Figma will create a “history” of frames you’ve visited when viewing the prototype.
  • will go to the previous frame, if one is available.
  • will navigate to the next frame. If there is no history—like after using —then it will navigate to an adjacent frame you haven’t visited.
Prototypes without a flow starting point
If a prototype doesn’t have a flow staring point, Figma orders frames based on their co-ordinates in the canvas. First, by their x co-ordinate from left to right, then their y co-ordinate from top to bottom.
If the y co-ordinate is offset in any way, then frames may appear out of order. To fix, you can set horizontal alignment for each row of frames to align-top.
  • will go to the previous frame if one is available.
  • will navigate to the next frame. First by x co-ordinate, then y-co-ordinate.
Gayani_S
  • 2111 replies
  • July 18, 2024
Hey @Vojtech_Lacina, thank you for taking your time to give us an in-depth feedback!
I am going to share this internally with the team for consideration.
Please feel free to upvote your feature request. This helps us roadmap future updates.
Thank you,
Gayani
