Managing memory erros in a file with large PNGs
  • September 6, 2024
  • 28 views
Nabeelo
I understand Figma has a 2GB limit. I have a project with multiple large PNGs, just the nature of the project, that are made for print.
There are not many components or layers in this project, compared to most, yet a simple 8-10 large PNGs are causing memory errors and causing Figma to through the memory error screen on a very regular basis whenever I edit anything in the component that modifies the overlays on those 8-10 PNGs.
Any suggestions for how to deal with large PNGs and their requisite pull on memory in Figma?
  • 2545 replies
  • September 9, 2024
Thanks for reaching out. There’re several things you can do to reduce memory usage. Can you try the troubleshooting listed in this article?
Figma Learn - Help Center
If the issue still persists, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
I hope this helps.
Nabeelo
  • September 9, 2024
Well yes. I looked at the help and went through the steps before posting for extra help.
  • There are essentially no hidden layers
  • I have taken several pages and split them into two files
The page that keeps breaking is just a single component, with 8 larger images (see attached). I cannot compress the images a ton as they are meant for print so will get artifacts, and they arent THAT big - like 3-5 MB each. They are PNGs if that matters.
The component is maybe 25-35 elements with a few layers, doesn’t “feel” crazy?
  • 2545 replies
  • September 9, 2024
Thanks for sending the screenshots. Yeah, it doesn’t look that big to me either.
So, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Our support team will look into it.
Thanks for your patience.
