Hey @Nick_Davis,
On the Starter plan, team admins can see the following information:
Name: Their name, profile picture, and email address. Click the email to copy the address to your clipboard.
Last active: This is the date they took an action in Figma, this doesn’t have to be an edit action. For example: moved a file, viewed a prototype, published a library.
Team permissions: What level of access they have to the team. If a member doesn’t have team-level permissions, you’ll see how many files they have can edit instead.
Sort and filter members:
- Use the Search field to find a specific member.
- Use the drop down fields to filter members by the following criteria:
Last active: More than 7 days, More than 30 days, More than 3 months.
Team permissions: Owner, Admin, Can edit, Can view.
- Click Name, Last active, or Team permissions header to sort by that column. Click again to switch between descending ↓ and ascending ↑ order.
More info here:
Figma Help Center
If you have any other specific questions, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Apologies, but this doesn’t answer the question I asked.
For anyone else interested, it transpires that when you choose to upgrade your plan, you must pick a Team to upgrade, and you are then given a choice as to which Team members become designers and which remain on the Starter plan.
So, you can create a Team on the Starter plan and choose to upgrade that Team, remain on the Starter plan yourself, and upgrade other members’ plans.
