Loading animation isn't playing
I’m new to using figma so I’m definitely still learning. I followed a tutorial on how to create a loading animation but when I go to play it, it doesn’t animate at all. I don’t know if I’m missing something or if I did it wrong so any help would be greatly appreciated.
Figma – 29 Mar 23
Best answer by tank666
  1. Select variant in the component set;
  2. Change the angle of rotation to 0°;
  3. Select the variant’s child layers;
  4. Change the angle of rotation to the degree you need;
  5. Repeat the above steps for other variants.
  • 4873 replies
  • March 29, 2023
How do I do that?
  • 4873 replies
  • March 29, 2023
spa
  • March 20, 2024
thanks, this solved the issue.
Vignesh7
  • September 9, 2024
I have the same problem. But I made a loading bar. Its not in a rotated position, but not working.
  • 4873 replies
  • September 10, 2024
Unfortunately, this information is not enough to determine the problem. Please provide more details (including information about the properties of the objects) or share a link to the example file so that anyone can explore it.
Vignesh7
  • October 6, 2024
This problem is not only in loading bar animation. It occurs with all animations. For example, after completing an animation and clicking the present button to see the output. But that animation doesn’t working. The animation only works after I refresh the present page.
Project Link
  • 4873 replies
  • October 7, 2024
Remove unused delay interaction from “iPhone 14 & 15 Pro Max” frame and also reset interaction override from “loading bar final” instance.
