List of Fonts in selection (like selection colors)
NAGA_TARUN
    When we select a particular template or frame on Figma on the right side it will show all the colours did we used on that frame or template that’s a really good feature, Including that can you people also try to show us what all fonts that we used in that template or frame I felt that could be really great move by Figma if you people show the list of fonts that we used in that frame this going to be a great initiative by FIGMA. I’m really apologetic If that feature already existed in Figma I didn’t know where it was? I explored but I couldn’t find that feature.
    (e.g. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this? etc.
  • 4708 replies
  • March 22, 2021
Font Fascia plugin allows you to see the list of fonts in the document:
Figma
NAGA_TARUN
  • March 24, 2021
Thanks so much Gleb, it’s working 👍 👍 👍
Marc_Nothrop
That plugin is OK for listing the fonts as you describe, while I’ve also been thinking it’d be great if we could see and modify all font in a selection as you can with Colours.
Further, like the Colours feature this could let you quickly select and change a sub-set of manually formatted text objects over to Text Styles.
That could help cleaning up after quick/loose ideation sessions (esp multi-player) much quicker, be less error prone and just feel so much more efficient compared to having to individually click to selects the various text objects in a selection – it feels cumbersome pretty quickly and it’s these sorts of efficiencies that really add up in loyalty/“stickiness” (if we must! 😉 )
While size also has to be taken into account, the colour feature’s already multi-modal with each opacity level a separate editable selection, just as differing sizes would be for fonts.
Finally, as colours are currently separate from Text Styles, the existing colour selection feature would of course also be available on the selected objects.
Hugo4
  • August 19, 2021
WE NEED THIS ASAP!!! I can’t understand why this feature isn’t ready yet. The selection colors feature is great to keep all designers in line with the colors in the library. The same needs to happen with text styles, otherwise, we can’t keep a 100% controlled design system. They also included effect styles now, that too needs a selection feature like the colors. We all want Figma to be the number 1 design system tool, but these are major features that are missing and we can’t understand why, since you already have that for colors.
DoPeT
  • March 13, 2022
+1 Bump!
Selection colors is brilliant for changing mass styles at once. This would be an incredible feature if it was the same for text styles.
Jay33
  • July 3, 2023
On selecting main frame we get list of colors that are present in it. Similarly we need something that allows us to change the font
Celine_
  • 3529 replies
  • July 4, 2023
Hi @Jay33 ,
Thank you for your idea! I merged your topic with a similar one as others in the community have requested something similar. 🙂
Lloyd_Young
Which one @Celine_Figma ? Can you provide a link so we can vote there also please? Thansk!
Celine_
  • 3529 replies
  • December 15, 2023
Hey Llyod!
It’s been automatically merged, so all votes have been gathered together automatically here.
If you haven’t vote yet, you can vote up here directly in this thread (next to the title of topic). Thank you!
Vivek_Chandarana
Like we have All colors we used in file showing so why it isn’t same in fonts?
Tom_Auger2
  • 30 replies
  • April 17, 2025
Yes, this is a much-needed feature. The ability to, for example, make a selection around a number of objects that include some nested text fields, and change the font size, weight, even face would be phenomenal - as others have said the “Selection colors” is a brilliant and indispensable options. Doing so with fonts and maybe even effects could be a great feature. Please consider it.
Tom_Auger2
  • 30 replies
  • April 17, 2025
As an alternative - is there a way to have a selection and then perform a command to select ONLY the text fields within that selection? That might satisfy some of the use cases here…
I see a “Select all Text Layers” but that’s weird - it seems to select all text layers within the outermost frame, not within what is currently selected. There doesn’t appear to be a “Select all Text Layers within current Selection”.
emma.s
  • May 7, 2025
Yes please!
Aaron_Schapiro
Still need this to happen
