List all the properties of a component instance
Nidhin_Kuttikkattu_Rajeevan
How can I find all the properties of a component instance?
const instanceVariant = Figma.currentPage.selection[0] as InstanceNode
const allVariantsNamesArr = instanceVariant.mainComponent.parent.children.map(
(child) => child.name
This command prints all variantProperties. But I wish to list all properties.
  • 4873 replies
  • June 2, 2023
Thanks Tank…
Here, I tried to print instance.componentProperties is doing the job…
Could I ask, can I set these properties from plugin? For example, if there is a property,
LightStatus = false,
can I set LightStatus = true?
I have done this, but only problem is,
node?.setProperties({LightStatus : false })
But I can’t give like that. It is as a string in an array.
I mean,
let nodeProperties: Array;
nodeProperties= [“LightStatus”,“WindowStatus”]
let nodevalues: Array;
nodevalues= [“false”,“true”]
in a loop, I have to set like
node?.setProperties({nodeProperties[0] : nodevalues[0]})
is it possible?
  • 4873 replies
  • June 2, 2023
Yes, sure. But note that you can only set properties that exist in the component/component set. Also note this:
Unfortunately, i am getting error. A help will be really appreciated.
Attaching what I have done:
//This target node is an instance actually. Please ignore about getNode(), I am not giving
//explanation of it, but it returns a component instance.
let targetNode = getNode(workingClone)
let tI = targetNode as InstanceNode
//This tI has more than //20 properties. I listed them using propDefs. so, it prints
//present set values.
const propDefs = tI.componentProperties;
//now, I have a test object. it is something like below.
testCase
{ nodeName - It is string
nodePropertyName it is string
nodeValue it is string
I am trying to populate a object that I can use inside setProperties() function for the targetNode
so following block will generate a result object. But I get error as above.
for (const prop in propDefs) {
    let propertyNameWithoutHash =   prop.substring(0,prop.indexOf("#"))
    if(propertyNameWithoutHash ===testCase.propertyName)
      result[prop]=testCase.value
      break;
  targetNode.setProperties(result)
Actually, the target property type is boolean. I am passing a string “true”. I am sure error is because of that. But hardcoding always True/False is not right way I felt.
  • 4873 replies
  • June 5, 2023
Sorry, I didn’t understand you right away. The false and true values ​​must be of boolean type.
Yes, I can set it now. Thank you. I will have to try the Variant type also
for a variant property, I am getting this error.
Error: in setProperties: Unable to find a variant with those property values
But I am sure, it is. For example,
FRUIT is the property name, and possible values, APPLE, ORANGE, BANANA.
I tried to set BANANA
code is
result = {}
result[FRUIT]= “BANANA”
One thing I noted that, when I was working with booleans,
each items in propDefs had a #value for example Fruit#148:15
but in failed case,
it is not
  • 4873 replies
  • June 8, 2023
Could you share a link to the test file?
I do not have a test file. So I am not able to share it. But I found the problem. It is not because the variant setproperty issue. Actually, the mainComponent of the target Node has combination of variants as below.
FRUIT = BANANA, COLOUR=RED, PRICE = LOW
FRUIT = APPLE , COLOUR = GREEN, PRICE = MEDIUM
FRUIT = ORANGE, COLOUR = ORANGE, PRICE = LOW
In my plugin, I am trying to set FRUIT = BANANA, but at this time, COLOUR = GREEN, PRICE= MEDIUM. But that combination is not exist. So, it reject the setProperties request.
my csv is having 3 lines actually
fruit:banana,
colour:red,
price:low,
since I am trying to call setProperties, line by line, it crashes. Can I set all three properties together in a single call?
  • 4873 replies
  • June 13, 2023
Yes, of course, you can set multiple properties at once when you call this method. Just add these properties to your object.
OK. I will try to iterate the csv file sequentially, then I will fill a result{} array,
after that I will try to feed that result into the setProperties…
Thanks Tank. It is working fine… Thank you.
