Keyboard shortcut for go to main component
  • July 26, 2023
  • 8 replies
  • 1481 views
mmmm
Previously you could map a keyboard shortcut for Go to main component in library but that menu option now appears to be missing, thus breaking the keyboard shortcut set up in macOS system settings. Now the only way to get to the main component is via a context menu in the canvas or clicking the button on the right panel. Neither of which is mappable to a keyboard shortcut.
This post was solved with the keyboard shortcut until that menu item was removed.
It seems dumb but I honestly used that keyboard shortcut every day and it will be sorely missed.
Best answer by Ryan_52
Thank you for your patience while our engineers worked on resolving the issue. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
Chaewon
  • July 27, 2023
Thanks to your post, I finally know why the shortcut doesn’t work all of a sudden.
It’s not dumb at all and it’s a very uncomfortable change…
kkone
  • July 27, 2023
Yes,I can’t use my shortcut keys today either today( go to main component)
David_Cortizo1
I ran into this issue as well, now my shortcut does not work and cannot change it to anything. I need this to be fast and productive.
Roman_Bartos
I cannot understand why Figma doesn’t do a proper UI for mapping ANYTHING to ANY keyboard shortcut. They work on videos, figjam… But we need to work in Figma!
Tom_Bruzda
  • July 28, 2023
I also used that shortcut (which I set up through keyboard settings on mac) every day. Now I have to go through right-click menu which isn’t effective at all. Will they give this option back at least to the global menu?
Ryan_52
  • July 28, 2023
Hi everyone, thank you for raising this issue. Our engineering team is actively investigating the issue to determine its root cause and working towards a solution.
Ryan_52
  • July 28, 2023
Boni_Amin
  • March 14, 2024
Log out and then log in again. It will be solved.
