Keep fixed size while using scaled position
  • November 24, 2022
  • 1112 views
David_Querg
Today, when setting “constraints” to “scaled” the behavior gets applied to both the position as well as the size of the layer.
I ran into a particular case in which I would like to scale the position relatively to its parent but keep the size fixed.
The example is straight forward.
  • I built a audio meter component which will be animate for prototyping and testing purposes.
  • The component itself as a particular height of 200px as a default.
  • Instances might use different heights.
  • The audio meter will display the audio peak in a given timeframe. (That’s the little yellow bar at the top)
Now: As is, the peak indicator gets scaled down as I decrease the size of the instance. Using any other constraint setting mispositions the peak indicator.
I don’t see how I can achieve a fixed height of 1px for the indicator while keeping a % based position relative to the height of the parent container.
(Left: instance with ~50% of the height | Right: Component variant)
Thanks for any advice.
Potentially this is rather a feature request.
– David
  • 4873 replies
  • November 24, 2022
If I understand you correctly, then Layout grid from rows can help you.
David_Querg
I think you are correct @tank666. I missed that approach but found another solution which is a bit workaround-ish.
  1. Put peak indicator into an auto-layout frame.
  2. Set peak indicator width to fill for scaling support. Height to fixed.
  3. Set auto-layout frame constraint to “scaled” for vertical.
Since I used an entire auto-layout setup for the entire component with L+R indicator I needed to set the height and width to fill again for the parent containers.
Generally my request is solved although it feels a bit overly complicated.
  • February 22, 2023
