Is there any way to set count for the number of triggers for a delay animation?
  • December 2, 2022
  • 5 replies
  • 674 views
pkp
I am making an animation which will trigger after 2 seconds and won’t trigger again. I am using the ‘After Delay’ to do this but the problem is that it triggers every 2 seconds. How can I stop the animation after triggering once. Is there any way to set the number of counts that an animation should trigger. Also won’t this be a good feature to have
Best answer by dennsi
It is normal behaviour since you switch the Bubble components “Current” state back to “Normal” state after a delay. This triggers the intial delay based “change to” animation again.
If you want to just display the state and color change once you’ll need a third variant in the Bubble component (you can call it “Last” for example). This is basically a duplicate of the first state but without any animation. Switch the change to from “Current” to “Last” instead of “Normal”.
See test document:
https://www.figma.com/file/HjMEdjy2wQzQ8o7BID4NVT/Trigger-animation-once-(Copy)?node-id=0%3A1&t=LXNNhYSlVwDD8UWU-1
Prototype:
dennsi
  • 256 replies
  • December 2, 2022
Can you provide a test file to look into?
pkp
  • 29 replies
  • December 2, 2022
Test file added
dennsi
  • 256 replies
  • December 2, 2022
See test document:
Prototype:
pkp
  • 29 replies
  • December 2, 2022
This is so true. Why didn’t I ever think of that. Thanks a lot for the quick solution.
dennsi
  • 256 replies
  • December 2, 2022
No problem youre welcome 😁
