Is there any way to check if a instance is up-to-date
Aaron_Xu
I want to writing a script that can update all instance inside a frame which is selected. So I need to check and update instance inside. But I can’t find a right api to do that.
  • 4707 replies
  • April 3, 2024
What do you mean by update instances? Which API specifically can you not find?
Aaron_Xu
  • 19 replies
  • April 5, 2024
When I use Figma for design, if a instance has a newer component version in team library, it show symbol like this:
And I was wondering if there a API that can check if a instance “can update”.
Aaron_Xu
  • 19 replies
  • April 5, 2024
You know, for my Figma plugin development.
  • 4707 replies
  • April 5, 2024
Unfortunately there is no direct API for that but it’s possible to do.
To find if instance is up to date:
  • Get its main component ID and import it
  • Check if importedComponent === instance.mainComponent
  • If they are different, the instance can be updated
To update the instance:
  • instance.swapComonent(importedComponent)
Aaron_Xu
  • 19 replies
  • April 5, 2024
OK, let me try it later
Aaron_Xu
  • 19 replies
  • April 12, 2024
It’s work!
I post my function code in case someone needs it
async function checkIfInstanceIsUpdated(instance: InstanceNode) {
    try {
      const asyncMainComponent = await instance.getMainComponentAsync()
      if (asyncMainComponent != null) {
        const importedComponent = await figma.importComponentByKeyAsync(asyncMainComponent.key)
        if (importedComponent != null) {
          return (importedComponent.id == asyncMainComponent.id)
      return null
    } catch (error) {
      console.log("error ! " + error)
      return null
  async function checkAndUpdateInstance(instance: InstanceNode) {
    try {
          if (importedComponent.id != asyncMainComponent.id) {
            console.log("update")
            instance.swapComponent(importedComponent)
            return instance
      return null
    } catch (error) {
      return null
