Is it possible to import the AWS client SDK into a plugin?
  • April 11, 2024
  • 249 views
I’m trying to use @aws-sdk/client-s3 in my Figma Plugin to upload an exported page as a PNG, but I’m receiving a “Unexpected token .” in the console when running the plugin. I think this happens when trying to instantiate the S3 client.
I assumed because this package can be included in the browser, it would be possible to import this into my Figma plugin, but maybe my assumption is wrong.
Here’s my setup:
manifest.json
  "name": "<redacted>",
  "id": "<redacted>",
  "api": "1.0.0",
  "main": "dist/code.js",
  "capabilities": [],
  "enableProposedApi": false,
  "editorType": [
    "figma"
  "networkAccess": {
    "allowedDomains": [
    "reasoning": "Do what I want",
    "devAllowedDomains": ["http://localhost:6069"]
  "documentAccess": "dynamic-page"
webpack.config.js
const path = require('path');
const webpack = require('webpack');
module.exports = (env, argv) => ({
    mode: argv.mode === 'production' ? 'production' : 'development',
// This is necessary because Figma's 'eval' works differently than normal eval
    devtool: argv.mode === 'production' ? false : 'inline-source-map',
    entry: {
        code: './src/code.ts' // This is the entry point for our plugin code.
    module: {
        rules: [
            // Converts TypeScript code to JavaScript
                test: /\.tsx?$/,
                use: 'ts-loader',
                exclude: /node_modules/,
    // Webpack tries these extensions for you if you omit the extension like "import './file'"
    resolve: {
        extensions: ['.ts', '.js'],
    output: {
        filename: '[name].js',
        path: path.resolve(__dirname, 'dist'),
tsconfig.json
  "compilerOptions": {
    "target": "es6",
    "lib": ["es6"],
    "strict": true,
    "typeRoots": [
      "./node_modules/@types",
      "./node_modules/@figma"
    "outDir": "./dist",
    "allowJs": true,
    "moduleResolution": "node",
    "sourceMap": true
  "include": ["src/**/*.ts"]
src/code.jts
import {S3} from '@aws-sdk/client-s3'
(async () => {
  const s3 = new S3()
  ...<redacted>
Luke Novak
  • March 17, 2025
+1
I know this thread is a year old but were you ever able to resolve this library? Other dependencies don’t seem to have this issue. Could use some guidance here from someone who has a little more experience building plugins.
