interactive components only work in another designfile
  • August 16, 2024
  • 5 views
Hello, I have an interesting issue.
I created an interactive component with variants. So I go to assets and insert the component into a frame. Now I go to present mode and the component is not working.
I then published the component and created a new designfile where i insert the component from the assetspanel into a frame and want to test it again. And now it works. How is that possible? It drives me nuts.
The component only works in a designfile where it was not created.
thank you very much in advance!
  • 2536 replies
  • August 21, 2024
Thank you for reaching out. I tried to replicate the issue but was unable to. Could you try below ?
Repair component connections
  1. Select a problem instance in a page
  2. The top left Figma icon > Quick Actions > Repair component connections
If the above does not not work, please try Regenerate all instances (slow)
  2. The top left Figma icon > Quick Actions > Regenerate all instances (slow)
If the issue still continues, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks!
