Interactions / On Drag : Add Drag Direction
  • August 19, 2021
  • 17534 views
ma2os
I’m building a simple prototype where a carousel of images can be swiped left/right to go to the next/previous image. I’m using the On Drag interaction but the problem is that it only accounts for one direction.
Imagine you have a strip of 3 images (A, B and C) where each image has the same width as the screen. If B is in the center, I can only use the On Drag interaction to go to either to A or C. Because there’s only one direction I can use.
This could be resolve by adding a specific direction for the On Drag interaction. On Left drag go to A, on Right Drag go to C.
This is a very common pattern. Does anyone figure out if there’s a work-around for this?
Thanks!
Best answer by tank666
Hi @ma2os, On drag trigger works in any direction. You can see some examples in this thread: How does the picture carousel realize the interactive effect of connecting the beginning and the end?
Help Center article:
https://help.figma.com/hc/en-us/articles/360040035834-Prototype-triggers#On_Drag
  • 4870 replies
  • August 19, 2021
ma2os
  • August 19, 2021
Ohhhh!!! I wasn’t aware you can add multiple ‘drags’ interactions to the same element. That’s exactly what I needed. Thanks!
  • September 18, 2021
