Image missing while export to pdf
  • January 31, 2023
  • 5 replies
  • 6469 views
Satyaviva
The image is missing when exporting to pdf, and it appears as white space in preview and output. Can anyone to tell me if there is any solution for it?
  • January 31, 2023
@Gleb I have a problem regarding exporting files to pdf, few vector designs are missing, I have tried every possible way(i.e aligning text vector inside the frame but still having the same issue, kindly provide some concrete information
  • May 28, 2023
That’s not what I said. Check the layers panel. The object you are trying to export has to be a child of the frame you are exporting. It should belong to the frame. In the layers panel. It doesn’t matter where it is on the canvas.
Natasa_Ilic
Hello, I have the same issue - images are missing, and the layers are inside of the frame where it’s belonging. When I export few pages it is fine, but when I export 200 pages they are missing.
  • December 26, 2024
When you export 200 pages from Figma, it runs out of memory and can’t keep all the images. Better export in batches and then combine everything into a single PDF with other tools (online tools or Preview on Mac). With a 200 page PDF you would have to use external tools anyway to get a decent size as Figma’s export is quite bad and outputs humongous PDFs.
