How to make transparent stroke
  • December 18, 2023
  • 2155 views
weirdo_man
How do I make a stroke transparent and make everything behind it transparent. This is an example of the effect I’m trying to achieve.
Screenshot 2023-12-18 172705
Haroll
  • 273 replies
  • December 19, 2023
Hi @weirdo_man
You won’t be able to achieve such a result with a transparent stroke. A stroke may be transparent but won’t hide anything below itself
I can see 2 ways of doing this :
  1. Use a stroke, set it to “outside” and manually pic its color so it’s the same as the one in your background
  2. Use a subtract selection so you can remove the “stroke” from the rectangle below:
    a. Add a stroke to the top rectangle, then disconnect it (cmd+shift+O or ctrl+shift+O)
    b. make sure the stroke is above your rectangle
    c. select them (rectangle and stroke) and use a subtract union
Hope it helped
