how to convert a Photoshop radial gradient to a Figma radial gradient using code.
I want to get a function that is a conversion from Photoshop to Figma. I referred to the Transform API transform and used the following code to implement it, but I didn’t get the correct result.
  const radians = (angle * Math.PI) / 180
  const cos = Math.cos(radians) * scale
  const sin = Math.sin(radians) * scale
  const gradientTransform: Transform = [
    [cos  , sin, offset.x ],
    [-sin, cos, offset.y],
how can I get the correct effect for the gradient radius and gradient direction?
below is json code
          "top": 0,
          "left": 0,
          "bottom": 0,
          "right": 0,
          "blendMode": "normal",
          "opacity": 1,
          "clipping": false,
          "transparencyProtected": false,
          "hidden": false,
          "name": "添加游记",
          "id": 316,
          "sectionDivider": {
            "type": 1,
            "key": "pass",
            "subType": 0
          "protected": {
            "transparency": false,
            "composite": false,
            "position": false
          "layerColor": "none",
          "timestamp": 1723014867.722276,
          "referencePoint": {
            "x": 0,
            "y": 0
          "version": 80,
          "opened": true,
          "children": [
              "top": 1314,
              "left": 319,
              "bottom": 1427,
              "right": 432,
              "opacity": 1,
              "clipping": false,
              "hidden": false,
              "name": "按钮渐变背景",
              "vectorFill": {
                "type": "solid",
                "name": "Two Color",
                "smoothness": 0,
                "colorStops": [
                    "color": {
                      "r": 246.0000005364418,
                      "g": 171.19999587535858,
                      "b": 58.99999648332596
                    "location": 0,
                    "midpoint": 0.5
                    "color": {
                      "r": 248.62500607967377,
                      "g": 62.59130157530308,
                      "b": 21.75468385219574
                    "location": 1,
                    "midpoint": 0.5
                "opacityStops": [
                    "opacity": 1,
                    "location": 0,
                    "midpoint": 0.5
                    "opacity": 1,
                    "location": 1,
                    "midpoint": 0.5
                "style": "radial",
                "angle": 90,
                "scale": 2.919859640880525,
                "offset": {
                  "x": 0.6470588036828727,
                  "y": -0.3012715328884816
              "vectorMask": {
                "paths": [
                    "open": false,
                    "operation": "combine",
                    "knots": [
                        "linked": true,
                        "points": [
                          345.62431275844574,
                          1425.000949382782,
                          375.99997222423553,
                          1425.000949382782,
                          406.37563169002533,
                          1425.000949382782
                        "linked": true,
                        "points": [
                          430.9999644756317,
                          1400.3766174316406,
                          430.9999644756317,
                          1370.0009388923645,
                          430.9999644756317,
                          1339.6252603530884
                        "linked": true,
                        "points": [
                          406.37563169002533,
                          1315.000928401947,
                          375.99997222423553,
                          1315.000928401947,
                          345.62431275844574,
                          1315.000928401947
                        "linked": true,
                        "points": [
                          320.99997997283936,
                          1339.6252603530884,
                          320.99997997283936,
                          1370.0009388923645,
                          320.99997997283936,
                          1400.3766174316406
                    "fillRule": "non-zero"
                "invert": false,
                "notLink": false,
                "disable": false,
                "fillStartsWithAllPixels": false
              "vectorOrigination": {
                "keyDescriptorList": [
                    "keyShapeInvalidated": true
              "id": 318,
              "blendClippendElements": true,
              "blendInteriorElements": false,
              "knockout": false,
              "protected": {
                "composite": false,
                "position": false
              "timestamp": 1723014867.722272,
              "vectorStroke": {
                "strokeEnabled": false,
                "fillEnabled": true,
                "lineWidth": {
                  "value": 1,
                  "units": "Points"
                "lineDashOffset": {
                  "value": 0,
                  "units": "Points"
                "miterLimit": 100,
                "lineCapType": "butt",
                "lineJoinType": "miter",
                "lineAlignment": "center",
                "scaleLock": false,
                "strokeAdjust": false,
                "lineDashSet": [
                "opacity": 1,
                "content": {
                  "type": "color",
                  "color": {
                    "r": 255,
                    "g": 0,
                    "b": 0
                "resolution": 72
              "referencePoint": {
                "x": 0.21875,
                "y": 0.21875000000022737
              "version": 130
