How do I get figma assets, components & variants via Rest API
  • September 7, 2021
  • 4699 views
Nalin_Agrawal
I am trying to fetch information about variants of a component. Which node returns that info.
Is it a different endpoint?
I tried GET team Components, GET file components. Both return an empty array. GET file does not seem to return any information about variants.
Thanks
Best answer by Gleb
GET file returns all file data, including the components and component sets that are in this file. You just need to find them in the file structure.
  • 4710 replies
  • September 7, 2021
RachelFranklin
I already use the approach mentioned by @Gleb but it is laborious and expensive when searching through large files, so was excited to see there is a dedicated endpoint for retrieving a file’s components.
However, I’m having the same issue as @Nalin_Agrawal - the file components endpoint keeps returning an empty array. Has anyone seen this before, and managed to resolve it?
This is the structure of my request:
curl -H 'X-FIGMA-TOKEN: <my-auth-token>' 'https://api.figma.com/v1/files/6HQRQOxFtpc8mppUXgcgLz/components'
  • 4710 replies
  • May 23, 2022
Are your file components published to the library?
