How do I center align content within properties?
I’m trying to have the entire content center aligned at all times within a property.
For example I created a Figma thumbnail that contains
  • Status icon “In progress, review, completed” etc.
  • File Name
  • Subtitle
I already figured out the the variants and properties.
But when I change the file name to something very long, instead of centering the enter content, the entire placement stays the same and pushes everything else down.
Dennis_N
  • 188 replies
  • April 21, 2023
If I get you right it sounds like you just need to center the text via text alignment and set the text box to auto width or give it manually a wider width.
That content get’s pushed down if it exceeds and line breaks happen is normally a wanted behavior and is caused by auto layout.
You should also center your auto layout:
Otherwise a screenshot of your issue would be helpful to better understand it.
  • May 21, 2023
