How can i make responsive a vector image
  • September 19, 2024
  • 13 replies
  • 226 views
Gabriela_Ghita
I’m new in Figma, but i want any vector image to scale when i drag the card. I don’t want the scale tool, i just want to know how do i make any vector image (in this case: those circles) to scale along the responsive card. In the third image i scaled manualy. Is the way i want it to look. How can i scale it down when i make the card smaller/wider.
Nellya
  • 647 replies
If you need proportional scale, use this plugin
Gabriela_Ghita
hello. perhaps i didnt say it right( english is not my mother tongue). I need to konw how to make a vector image smaller with the frame, not to lock the ratio.
When i make the frame smaller, the vector image to bacome smaller with it.
Thank you anyway
Nellya
  • 647 replies
  • October 1, 2024
There is no proportional scale in autolayout in Figma right now, that’s why i recommended to use a plugin. I guess it should resolve your problem
Luke-Itineris
  • 129 replies
  • October 1, 2024
Just export the vector as a png, and add it to the frame.
Or, just add the vector inside a frame.
Nellya
  • 647 replies
  • October 1, 2024
It wouldn’t work, because she needs the proportional scale like shows in the 3th screenshot.
The bigger image became smaller, with the same aspect ratio.
Luke-Itineris
  • 129 replies
  • October 2, 2024
This would work just fine.
Nellya
  • 647 replies
  • October 2, 2024
Can you share a video or a file, please? I’d like to know how to make it works without plugin too.
Luke-Itineris
  • 129 replies
  • October 2, 2024
What do you need a video of? All I’m saying is
Go to Illustrator > export vector shape as png > go to Figma > create a frame inside your card > add image > done.
Nellya
  • 647 replies
  • October 2, 2024
I mean how it helps to solve the problem with a image scale in the responsive card?
Luke-Itineris
  • 129 replies
  • October 2, 2024
Nellya
  • 647 replies
  • October 2, 2024
I see, image can’t get bigger, than the original and left a blank gaps above and below image if gets smaller, but it’s still work, thanks for the video!
Layla
  • October 3, 2024
I found that the image can’t go beyond its original size, leaving some gaps if it shrinks, but it’s still effective! Appreciate the great video.
Gabriela_Ghita
i will definitely try this plugin again. I don’t know why it didn’t work for me. Maybe because i m so new with Figma, but what you showed in the clip is exactly what i needed, thack you!
