Same here. Glad I’m not crazy. My interactive components have been functioning flawlessly for days, but suddenly went haywire. Same bug across multiple browsers, Figma Mirror iOS app as well as MacOS desktop app.
@Andrew_Chan It’s certainly much better, the hover issue is gone. Thanks to the team for jumping on this so quickly!
I’m finding that click interactions aren’t registering until maybe the third or forth click. Not sure if it’s related or not, but it wasn’t happening on the same prototype as it was yesterday.
That seems unrelated, but also a bug. If you can consistently reproduce this, do you mind sharing a link to the file with me via DM? You can make sure I have access by inviting me at achan@figma.com. A video of the issue occurring would also be very helpful.
@Andrew_Chan I have an issue with nested hover states getting “stuck” ie. a button inside a table row, both with a hover transition, if you hover both then frequently the button gets stuck in the hover state (top level row doesn’t seem to get stuck). Possibly related to this bug?
Same problem almost a year later… hover state in interactive component gets stuck and I have to use a workaround like linking the hover state back to the original state using the “mouse leaves” interaction which I’ve never used before.
I view community-cloned button prototypes that were built the same way and they still seem to work fine. All of a sudden just all of my hover states stopped working across my entire design system and i’ve had to go back and fix every little atom
Hi, I have a similar issue here, it seems the hover interaction doesn’t work at all, I can only do the trick with → Mouse enter + mouse leave.
Does anyone knw a fix to this?
Thanks.
Same issue here. When using “while hovering”, the components somehow get into this crazy state, where some elements have different colors and get stuck into some weird state. Please fix it, @Figma_Support
Edit 1: added a video to this post. There you can see that the icons are keeping a blue color after the hovering, but shouldn’t.
Edit 2: this happens in nested components. The icons are components, coming from a shared library, and the list items are local components, (and part of a major component).
Hello @Andrew_Chan , I have a very unusual problem with what is hover, this problem has already seen some time ago but I thought it was my component configuration and now I see that the error continues, this is driving me crazy, and I sent you an invitation to my project in figma to your email achan@figma.com, just in case here I send you the link: https://www.figma.com/file/9LsSKYOntDG7r2Pfy0Xgkb/hover-problem?node-id=0%3A1
I’m also having a very similar bug where hover interactions aren’t working properly.
Checkout this prototype; Notice that the hover states on the tiles at the bottom have different font styles applied to their titles, that’s the issue.
