From an instance node, I’m trying to move up the tree up to the componentSetNode
, then to each componentNode
so I can grab every valid combination of component properties (sometimes components have unused combinations).
When I run . componentPropertyReferences
on the componentNode
, I’m getting an empty object back.
Is there another way to tackle this?
Here is how the componentPropertyReferences
property is described in the documentation:
All component properties that are attached on this node. A node can only have componentPropertyReferences
if it is a component sublayer or an instance sublayer. It will be null
otherwise. The value in the key-value pair refers to the component property name as returned by componentPropertyDefinitions
on the containing component, component set or main component (for instances).
Therefore, to get the componentPropertyReferences
, you need to traverse the tree of children, its children’s children, etc.
Traversing the tree doesn’t show anything under componentPropertyReferences
for components under a componentSet. And componentPropertyDefinitions
isn’t what I’m looking for.
Have you traversed the children tree inside the ComponentNode
Yes I have, i went from instance → componentNode → componentSetNode → componentNode
InstanceNode.mainComponent.parent.children[0].children[0] // etc.
Why would I go through each element inside a component node? Thats extremely inefficient.
Only there you can get a non-null componentPropertyReferences
. I wrote about this from the very beginning.
