Figma ts Unexpected token error
  • July 11, 2024
  • 442 views
edDes
Simple code:
let newPage: PageNode = figma.createPage();
Error:
vendor-core-67cd853d…3a53b1.min.js.br:15 Syntax error on line 36: Unexpected token :
package.json
"scripts": {
    "build": "tsc -p tsconfig.json",
    "lint": "eslint --ext .ts,.tsx --ignore-pattern node_modules .",
    "lint:fix": "eslint --ext .ts,.tsx --ignore-pattern node_modules --fix .",
    "watch": "npm run build -- --watch"
What is going on here?
I don’t know I this helps in any way - but I was getting the same error. For me it turned out that Figma plugins (on Sonoma 14.5, Figma 124.2.8 no longer likes console logs. When I removed them - that error removed and all ran as expected. May not be the same issue though.
  • July 13, 2024
You are feeding it raw TS code but you need to compile it first. Make sure your manifest points to a .js file not a .ts file. And that js file needs to be compiled using the build command.
edDes
  • July 16, 2024
Correct, fixed, and thanks to @Gleb.
I am not sure where this code.ts came from in the manifest, but changing it solved the issue.
