Figma Slides – share a plain 'Audience' link, without the ability to open in Figma, view slide notes, or add comments
  • September 11, 2024
  • 14 replies
  • 1252 views
Dave_Montrose
I’m wondering if this is a bug.
Sharing a ‘Presentation link’ gives the recipient a view-only view of the working Figma file along with notes. Makes sense if there are other presenters and they need to see the notes too.
Sharing an ‘Audience link’ gives the recipient a view-only view of the slides. However, it also allows them – who will very often be a client – to click a button at the top to open a view-only version of the Figma file along with all of the presentation notes.
Unfortunately, it’s currently not fit for purpose to share a link with clients, as there’s no way to send it purely for viewing without all the additional UI options to open in Figma and view notes etc.}
Ideally, there needs to be a sharable ‘Audience’ view of the slides where all that can be seen is the slides – no extras, no ‘sign in’, no ‘add comments’ (ideally this can be switched on OR off), and definitely no ‘open in Figma Slides’. Just a view of the slides, and that’s it.
Dave_Montrose
For clarity – I’m hoping for something that looks more like the view of a prototype when using the embed code. Just a completely plain view, with a carousel control, and without the Figma branding at the bottom. And that’s it.
Dave_Montrose
For anyone else wanting a quick fix to remove all the UI and just show the slides, I added this to the end of the url before I shared it with the client:
&hide-ui=1
Not ideal, as it can just be changed by a viewer and they can still open it in Figma and/or leave comments, but fixes it for now.
Kimberly_Dziubinski
@Dave_Montrose thank you for trouble shooting this flaw with Figma Slides, that I just encountered myself! Thank you for the solution—I’ll try it!
I was at first excited to build a prezi staying in my favorite design tool Figma—and then really frustrated when realizing (after investing in creating 60 content rich pixel perfect slides) — that I can’t SHARE the slides without giving them access to controls and my original file.
Also when sharing a link, my clients were required to go through a Figma sign-in/sign-up process: this is a barrier to clients opening the prezi, period.
Q: Do you know, is there a way to share Figma slides that doesn’t require the audience to go through a sign in process before opening the slides?
Thanks
Dave_Montrose
Hey Kimberly – I’m afraid I actually ended up just transferring it all to Figma in the end. I’d created an agency creds deck, and really liked the fact I could use Adobe fonts, and include looping videos without controls, instead of gifs or YouTube-style videos like GSlides.
But I also noticed, as someone else on here has pointed out, that if you have video on a slide, hitting a key to move to the next slide takes a few presses. And I can’t send something like that to a client or prospect, or it’ll just frustrate them. so that kind-of killed it. In the end, I just used the embed/iframe function for the Figma prototype, and put it up on our company site in an unlisted url.
I’ll be holding off using Figma Slides again, esp for proposals, and sticking to Google until I can actually share the slides and just the slides, without a client or prospect being able to view the file and all the comments, and while things like comments and sign-in buttons don’t have an option to be hidden. Sorry I can’t give you a better/more helpful answer!
Andrew44
  • October 9, 2024
Agreed on all of this. We have found Slides to be indispensable in our work and we use it/Figma solely for building dynamic presentations (w/ the ability to use our fonts). Most times we’re sharing with clients who are on the business side of things and need an easy experience to view. Would be great to share without any of the open in Figma/share stuff at top, but with the left/right arrows/restart at the bottom for clear navigation.
Being able to have a thumbnail view as an option would be great too to quickly move up/down slides, but not any presenter notes, etc.
Korey_Vincent
I need to share a presentation link to a client and only allow commenting, while restricting access to view file and speaker notes, etc. Is this possible?
Deeeps
  • March 7, 2025
@dave, thanks for sharing that workaround. Has there been any updates here? Want to use figma slides with sometype of Audience mode. Just like sharing a pdf presentation. No interactions outside of viewing the deck.
ChiSenires
  • 25 replies
  • March 27, 2025
Adding to this conversation, I hope this is something the Figma Slides team can work on. It would be valuable to be able to share just the presentation or audience view without giving people access to the Figma Slides editor file, even if it’s just view only.
Farid1
  • April 9, 2025
Simply hitting the ESC key brings back the UI :/
@figma please fix this issue so we can use Slide for client presentations.
Thanks!
Corinne Sherry
I am also finding this a massive missing feature!
Flovo
  • May 5, 2025
Figma, get on it and fix this.
Give me the ability to remove the UI, especially the ability for the recipient to open the deck in Figma slides.
Corinne Sherry
It’s fixed! When in presentation view you can now share and get the audience link. You may also be able to get this view from the other Share link entry points.
Flovo
  • May 7, 2025
It’s not fixed. Anyone with the link can open the presentation in an unlogged in version of Figma slides and see the presenter notes.
Corinne Sherry
Good clarification! My need is met in that I can now send an audience link and embed a presentation without the thumbnails showing. (Also on mobile I don’t think you can get to that UI to login.) But if you want to completely prevent accessing the slides view then you’re right more work is needed!
