Sebastian_Irimescu
Aug 12, 2024 9:50 AM UTC
Figma slides - internal links between slides shouldn't become external links when exporting to PDF
Hello,
I tried Figma slides to re-create my portfolio, which I had already created in Figma, because I was attracted by the possibility to quickly reorder the slides. However, I noticed a problem: while I can create internal links in Figma slides which allow me to jump from a slide to another, when I export said slides as a PDF, the internal links are substituted with external links which jump back to the Figma website when clicked, instead of allowing you to navigate through the PDF inside your own pdf viewer.
This is a problem for various reasons:
  • you can’t easily navigate around the .pdf offline, since each time you click the supposedly internal links you instead get redirected to a web page;
  • the offline .pdf and the online version can be out of sync. Meaning that the offline versions, which may be several and have different slide orders or different elements (it’s common practice to slightly tweak a portfolio when you send it to different clients) will all point to the same figmaslides web version due to those pseudo-internal links.
The best solution would be to make it so that internal links in Figma slides, when exported to .PDF, remain internal links between slides also inside the PDF (and thus accessibile by any pdf viewer, online and offline) instead of pointing again to the Figma slides web version.
Hope this feedback reaches its intended target
Aug 19, 2024 3:18 PM UTC
Hey @Sebastian_Irimescu, thanks for the feedback!
We’ll pass this onto the Slides team for future consideration.
Vladlen_Voitenko
Sep 26, 2024 7:47 AM UTC
I support and would like to add that I would like to put links not only to text, but also to objects/group of objects. This is very necessary for interactive presentations, where the menu is present on every page for easy navigation through the presentation, if it has a large volume.
rubato
Jan 21, 2025 5:46 AM UTC
I really need a feature like this. Is it currently available? Or is there a plug-in that can provide similar functionality? Please let me know if one exists.
yumi nsh
Jan 30, 2025 4:20 PM UTC
​@rubato I am currently using a plug in called Pitchdeck. It doesn’t work completely nice, so i am on this forum to try to find a better option
Maescabra
Mar 7, 2025 2:47 PM UTC
Pitchdeck doesn’t work for me. There’s no link at all on my text objects after exporting the pdf. But they work great in Figma, just like the native version of internal links.
Kelly C
Jul 29, 2025 7:54 AM UTC
Any updates here? We can’t use this as a slides tool until we are able to have these links work
Thanks
Sebastian_Irimescu
Oct 23, 2025 8:54 AM UTC
Hello ​@djv
Have there be any updates on the issue?
Oct 23, 2025 3:44 PM UTC
Hey All, thanks for your patience!
Right now, the Slides team doesn’t have an updated timeline on this, but rest-assured, PDF and PowerPoint exports are still on their radar for improvement.
l38181898
Oct 23, 2025 4:20 PM UTC
Hello,
The best solution would be to make it so that internal links in Figma slides, when exported to .PDF, remain internal links between slides Explore more also inside the PDF (and thus accessibile by any pdf viewer, online and offline) instead of pointing again to the Figma slides web version.
Yes i see
coli
May 13, 2026 7:25 PM UTC
I completely agree with this. Internal navigation between slides should stay as proper internal PDF links after export, not convert into external browser-style links. This creates a poor presentation experience, especially for interactive decks and client presentations.
Would love to see Figma improve this behavior because many designers use PDFs for sharing presentations professionally. I also found this helpful resource about slide navigation and PDF workflows using reference.
