Figma library not detecting changes
Wessel_Grift
My Figma library is not detecting changes when I make them. It is driving me nuts. Other designers can see the changes though and are able to push them for me. My Figma just says: ‘Published and up to date’
I tried:
  • Using another account
  • Reïnstalling Figma (and deleting all the subfolders and logging)
  • The browser version
  • Checking if any layers are prefixed with ‘_’
  • Renaming components
Nothing works… any suggestions?
Best answer by Jacek_Zdunczyk1
See if any components thath you specifically made contain any unused properties. Exclamation circle when checking the component will indicate this state.
This causes a publishing bug for the author of the changes. Others can load the changes but you wont be able to reload your library until you resolve the missing/unused properties
Ive spent good 4 hours yesterday trying to figure out why my combobox component was fine when copied, but did not work when selected from the library menu.
This helped me, maybe that will help you
Rafael_de_Paula
Same for me.
Josh
  • Former Community Manager
  • 1019 replies
  • October 6, 2022
Hey all this should now be fixed. Can you try refreshing?
Rae_Gibbs
  • 7 replies
  • October 21, 2022
I’m still having this issue
Jacek_Zdunczyk1
davlad
  • November 16, 2022
It works for me. Thank you for advice.
Pepi
  • February 3, 2023
Thanks a lot! Worked for me, as well.
Thuan_Nguyen
You’re a lifesaver. Thank you.
Ryan_Purdy1
OMG this thread was a life-saver this has been plaguing me and destroying files for MONTHS
  • August 9, 2023
Bro thank you so much
Marcio_Gutheil1
Worked for me too
Thaisley
  • November 20, 2023
I’m having this problem. And I’ve already tried everything mentioned above.
  • 4845 replies
  • November 20, 2023
Sorry to hear the above solution didn’t work for you, @Thaisley!
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look.
  • December 15, 2023
Worked for me too. A year later. Thank you 💚
