Figma Glitches on Intel UHD 730. WebGL context lost error
Khawaja_Azwar
Hello Everyone, I am not sure if this is the right place to post the query. But I am facing alot of performance issues while using figma with my new Intel 11th Gen i5 11400 on intel uhd 730. I don’t have a graphic card installed in this pc. I have tried multiple drivers and ports but the problem still remain the same.
The figma screen is lagging like hell as soon as I start panning around and turns to completely grey.
Please help. Attached is the screenshot
Best answer by tank666
Launching Figma with the --disable-gpu-compositing flag helped me.
Create or edit a Figma shortcut so that the Object field reads: "C:\Users\%USERNAME%\AppData\Local\Figma\Figma.exe" --disable-gpu-compositing.
You can also launch Figma through the command prompt.
  • June 27, 2021
Restart Figma. Open the design file. Open console. Try to reproduce the gray screen issue. Check the console for errors.
Is there an error “WebGL: CONTEXT_LOST_WEBGL: loseContext: context lost”?
Khawaja_Azwar
@tank666 here’s the attachment for the error. After this the whole screen got grey as soon as I started panning and zoomed in. And I have to restart the figma and it goes again and again not letting me to work at all. 😦
  • June 28, 2021
Khawaja_Azwar
@tank666 it Worked 🙂 . A little laggy but overall alot better than Basic Adapter Driver experience. Thanks alot man. You saved my life. 🙂 👍
Khawaja_Azwar
@tank666 did it disabled the GPU acceleration? And how this issue will be resolved without disabling it? Thanks again
  • June 28, 2021
Unfortunately, I have not found another way. You can try changing the parameters in the GPU driver settings. Also contact support, maybe you will be prompted for a different solution.
Khawaja_Azwar
@tank666 it resolved it to some extent but didn’t fully resolved. The figma get’s stuck completely very often and starts to work again. 😦 I believe we have to wait for the update from either figma or intel hd driver. Let’s see. Thanks anyway.
111931
  • July 28, 2021
Bump. Have the same issue with UHD 750
111978
  • 7 replies
  • August 6, 2021
I have the same problem with Intel UHD 730. --disable-gpu-compositing flag does not solve the problem
  • August 6, 2021
Do you have a WebGL: CONTEXT_LOST_WEBGL: loseContext: context lost error in your console?
111978
  • 7 replies
  • August 6, 2021
on a hardware accelerated browser getting this error. Without hardware acceleration, everything is fine (for now).
I just don’t have time to see this error in the application. The application turns into a “gray brick”
111978
  • 7 replies
  • August 6, 2021
getting error when running this way
C:\Users\admin\AppData\Local\Figma\Figma.exe --disable-gpu-compositing
111978
  • 7 replies
  • August 6, 2021
the latest version of drivers from intel is installed (30.0.100.9684 14.07.2021)
https://downloadcenter.intel.com/ru/product/80939/-
  • August 6, 2021
Save debug info, open that file and find the table under “Graphics” section. Is “disable_software” set for “gpu_compositing”?
111978
  • 7 replies
  • August 6, 2021
i have this
111978
  • 7 replies
  • September 2, 2021
updated the program to the latest version and updated the drivers on the video to the latest, the problem did not go away.
is there any solution?
4Bos
  • September 11, 2021
Figma works fine in FireFox, but in Chrome and in the application the same problem as the author of the post (UHD 750).
Anton_Ryuben
I’m confirm this problem. I have an I5-11600 (UHD 750) and also have this problem. Figma works well in Firefox, but in all chromium browsers - crashing browser (or the program does not respond)
Khawaja_Azwar
Did you tried the latest hd driver from intel on the link below. It worked for me last time when I installed. Because after that I moved to external GPU so not sure if it still works. Give it a try.
Intel
Khawaja_Azwar
Please do confirm when you try that so it helps others as well. Thanks
111978
  • 7 replies
  • September 16, 2021
Driver Version - 30.0.100.9864 (Intel® Graphics – Windows® 10 & Windows 11* DCH Drivers)
Application (with gpu-compositing) - turns into a gray “brick”
Application (with --disable-gpu-compositing) - WebGL: CONTEXT_LOST_WEBGL: loseContext: context lost
Chrome, Opera - WebGL: CONTEXT_LOST_WEBGL: loseContext: context lost
FireFox - works
Driver Version - 30.0.100.9894 (Intel® Graphics - BETA Windows® 10 DCH Drivers)
Application (with gpu-compositing) - works, I will test it
Application (with --disable-gpu-compositing) - works
FireFox - works
Chrome and Opera can also be started with this flag.
Anton_Ryuben
at the time of writing this message, I already had the latest intel driver.
when I try to open large projects - figma constantly freezes and restarts.
but new or very small - everything is fine
Deryugin_Andrey
Same problem UHD 730 (i511400) both in Chrome and App. Latest drivers.
(But small projects or new works normal)
111931
  • September 27, 2021
So it’s definitely chromium (chrome/opera/edge) bug. Can we ask chrome’s team to fix it?
