Figma dashed stroke export bug
  • August 11, 2023
  • 10 replies
  • 1451 views
Kai7
Henlo Figma ppl! 👋
I’m trying to export a component as SVG, all fine and dandy except when I export it, the dashed strokes don’t appear to be the same as the ones in the design.
In Figma, I have this simple box component, exported to SVG, and it looks off, here’s a comparison:
Which has dashed lines off, Is this a bug? Anyway for me to fix this?
Thank you, and have a nice day! ヾ( ̄▽ ̄) Bye~Bye~
aboyswagger
Same issue here. Did you find a fix?
Kai7
  • September 24, 2023
I ended up contacting support, and unfortunately ended up losing patience as they kept switching topics, asking me for details I have already provided and genuinely felt like they were avoiding the question. Like— They told me “The gradient functions as expected” when I have never even asked or brought up gradients. So I gave up T^T
aboyswagger
Thanks for getting back to me. I’m gonna try to reach out to their support team. Maybe they will help, if not I guess I’m just gonna have to find something else to use like Adobe Illustrator.
Kai7
Good luck! I hope your experience goes better than how mine was. I’d be beyond grateful if you could get back to me with a fix if you end up finding one!
aboyswagger
Of course! I’ll let you know if they give me a solution.
aboyswagger
They have not responded to me yet, but after some experimentation I figured out a solution. I exported it as a PDF instead of an SVG.
Then, I used a PDF to SVG converter (PDF to SVG | CloudConvert).
Hope this helps!
  • November 9, 2023
This worked perfectly for me! Thanks for mentioning this workaround 🙌
Important note: with this method outlines are converted into vector objects. However, this is not my desired result and it’s also possible in Figma via “Object > Outline Stroke”.
aboyswagger
Thank you! This worked perfectly! Why does this fix it?
9136
  • October 16, 2024
The bug is still getting in the way. I have not yet found a way to solve the issue to get an SVG with a dashed stroke without accidental changes when saving. The “Outline stroke” one doesn’t suit me.
In fact, you need to redraw each stroke with a separate line to make it work.
It is necessary that either the SVG is preserved in its intended shape, or that it is possible to convert a dashed stroke into a solid one, while maintaining the appearance.
Screenshot 2024-10-16 at 12.37.00
