Figma burning artifacts into monitor
  • November 21, 2022
  • 5 replies
  • 920 views
Shane_O
I’m running two displays on a 2021 14-inch M1 MacBook Pro. Figma is the only application that causes these screen artifacts (verticals lines) to show up on my main display (LG 38WN95C-W 38"). Figma itself then becomes “burned” onto the screen.
Rajeesh
  • November 23, 2022
Shane, i guess its not the problem with Figma.
Screen burn is caused when the application (any application) layout stays on the screen in a fixed position for a long time. OLED screens will not be having this issue.
Hope most of the time you may be using Figma?
Try running a screensaver or video with lot of motions and colors. Leave it for sometime and check if it heals.
Shane_O
  • November 23, 2022
I’m certain that’s not the case. My energy settings shut off the displays after 5 minutes or so. Additionally, I switch back and forth between applications throughout the day. It’s only when Figma is opened or active that this occurs on the display.
SohrabNiroo
  • 188 replies
  • November 23, 2022
Hello @Shane_O
Figma uses WebGL, make sure your drivers especially Graphic Card are updated and I think your graphic card (Or CPU graphic depends on your machine) HDMI must support it.
Try using your monitor on a Windows and see if still occurs
I hope this helps
driesdriesdries
I have the same issue.
It disappears when I quit Figma. But starts when I launch it again.
Cmd-tab from Figma to Chrome, Miro, Finder, it disappears.
Cmd-tab from Figma to MS Outlook, MS Teams, Acrobat, Spotify, Telegram, Finder, MS Excel, it stays.
I’m on a MBP M3 Pro, OSX 14.1.1
Switching from OSX on USB-C to Windows on HDMI it disappears.
It’s so weird.
Vimi
  • September 3, 2024
i am also facing similar issue, LG49 UW MBP M2
Any solution?
