Fetch published variables via rest API
  • February 7, 2024
  • 734 views
I am trying to fetch all variables (names and color values) from Figma via two endpoints:
GET /v1/files/:file_key/variables/local
GET /v1/files/:file_key/variables/published
Both of them are currently in beta.
Via the local var endpoint everything works fine and I am able to fetch all var names and colors in this prop: “valuesByMode”
For the published endpoint on the other hand I am not able to fetch these values. The endpoint returns data, but somehow not color names and values. Also according to the api docs this doesnt seem to be intended and I am wondering why?
Am I overlooking something or is there any other way how to fetch Figma variables with names and values?
Valstar_L.R_Ron
Looking at this issue as well. The documentation leaves a bit to be desired. Did you ever find a solution?
It looks as though variables set in ‘published’ are also set in ‘local’. So I’m guessing one should fetch both, and then match ‘local’ values to the ‘public’ keys.
