Hello,
I am reaching out to express the need for a feature that allows direct duplication of pages to another file within Figma. Currently, the process of duplicating content by copying and pasting between pages is not only time-consuming but also becomes cumbersome when attempting to duplicate multiple pages to another file simultaneously.
I believe a feature that enables direct page duplication to another file would significantly enhance our workflow and efficiency. Such a feature would save considerable time and effort, especially in scenarios requiring the management of large projects with multiple pages that need duplication into different files for organizational or collaborative purposes.
Is there any plan to develop a feature that facilitates duplicating pages directly to another file? This functionality would be highly appreciated and could notably improve productivity and usability within Figma.
Thank you for considering this request. I look forward to any updates on potential developments in this area.
Best regards,
Hi @Bonnie_CX_CX
There are so many other things the Figma engineering and product team should be doing, I’m going to say that if you’re having to copy and paste so many files that it’s the repetitive task that is eating your time – you might just need better workflow or file management.
Have you fully explored the Components and Libraries feature?
I will alter what I think you want by selfishly proposing something that WE need – but might also be the thing you need as well.
Instead of duplicating, you could send a “Window” or a “Mirror” of any object into another Section or Design File (or FigJam). So, when changes are made at the Source, they are seen everywhere the Window is on the Canvas – across all the files that have that Window/Mirror. Components don’t do this, because you can’t grab things from components.
Let’s take a UI Kit, or a Brand Kit, or Design Guidelines. Sure, you can make every object in that kit a Component, and you can one by one import them into your other files. (Here actually your idea would be interesting, which is to just magically send a component to some group of files.). However, UI Kits and Brand Kits and Design Guidelines and all that are usually designed and structured themselves… So you have to recreate the design of the parent object, or the meta-components, in order to have all those actual components be organized in a schema and with documentation that makes any sense. Either that, or every time a designer wants to browse the component library, they have to LEAVE the file they are in, and GO to the UI Kit. It makes no sense.
Or let’s say that I’m creating variants on your designs. And your designs are complex, pages and flows and mobile and web and tablet. In order to see your files in my workspace, I have to duplicate them. Well, then they will be out of Sync as soon as you change something. Or, you could make everything you designed a component, and then you will have Page Components that reference Section Components that reference Element Components that reference Composite Components that reference Token Components. And I can’t grab anything from your design without retracing the Nested Component Tree like 26 layers deep. And by that time I forgot what I was doing.
That was a ramble. I’m in full support of a slightly less time consuming way to duplicate or send any object to another File. However, I think that will lead to another fiasco that needs cleaning up. So, I used to opportunity to suggest Mirrors/Windows as well.
Sorry to hog the mic, mic drop.
Hi @Bonnie_CX_CX, Thanks for sharing your thoughts! I completely understand how crucial it is for you to have the ability to duplicate pages directly to another file.
While we can’t make any guarantees or promises, I’ve made sure to pass on your feedback to our internal team for future consideration, and I’ve also moved this topic to share an idea where users can vote on the idea!
Hi @Michael_Staton, your suggestions and opinions are fantastic! We really value your input.
When it comes to file management, we have a best-practices article that might help: Team, project, and file organization
A big thank you to both of you for your valuable contributions. Now I’m curious about the community’s reaction, feel free to vote or comment here!
By the way, I came across a similar discussion here: Move a page from one Figma file to another
Feel free to check it out!
This is a feature my team would really like to have.
We would also like to be able to duplicate whole teams with all of the projects and files and/or duplicate projects to another team.
I guess the issue might be as you mature and gain more team members, any file management methodologies you had in the past, might not work, so you get to a point where you need to do a cleanup, and then you’re in trouble!
To maintain consistency and clarity across my Figma projects, I’ve developed a structured page layout that I apply to all my files. Each file is organized into three primary columns arranged from left to right: Requirements / Insights, Concept, and Design. When a new version is needed, an additional column is added—one per version.
To ensure a clean and professional appearance, I’ve also created a custom grid system using Figma’s rulers (see attachment).
However, when starting a new Figma file, I’m unable to copy the page template along with the rulers, comments, and locked elements from an existing Figma file. This means I have to manually unlock the elements before copy and pasting the content and recreate the ruler setup and lock the unlocked elements each time after pasting the content onto a new page—a process that is repetitive, unnecessarily time-consuming, and prone to error.
As others have pointed out, this kind of repetitive task is exactly what a tool like Figma should help automate. It would be incredibly helpful if Figma allowed users to copy and paste entire pages between files with rulers and comments preserved.
I hope this perspective promotes the topic of copying and pasting a Figma page into another Figma file with rulers and comments.
