Exporting anything results in blank folder
Moe2
Anytime I export an item it just downloads an empty zip folder
2022-04-18_21h43_27
Nelson
  • 8 replies
  • April 19, 2022
In your video, I noticed that your zip file had a number at the end (13).
Is it possible that your downloads folder has multiple copies of the .zip file? If so, could you check the file that doesn’t have a number at the end? Or try deleting all the duplicates before trying again.
I had the same issue today and discovered that the layer I was trying to import was named starting with a dot .image container. Solved it by removing the dot from the name.
Screenshot 2024-04-24 at 11.42.24
