Export PDF Files Creates Huge Files
Alex_Wolf
Hey Folk.
I’m trying to export a frame in Figma which has noch images, just text, forms, blurry layer…When I export this frame, the file size is around 18MB and I don’t get why?
I’m creating presentations with Figma and when you’ve 50 Slides… Do the math…
Any help here?
Best answer by djv
Hey @georgezikos, glad to hear your noticed the recent change!
This was actually a quiet launch pushed by the team a couple of weeks ago, but there’s more info from the team available here:
Celine_
  • 3688 replies
  • August 18, 2023
Hi @Alex_Wolf,
Figma only supports PDF exports at 1x , so there wouldn’t be a native option to export assets at a different scale. There are a couple options to workaround this though.
  1. This Community plugin helps you to compress PDF files upon export: Compressed PDF Exporter or TinyImage plugin
  2. If you don’t mind keeping objects in PDFs as vectors, you can export all frames as JPEG while reducing the scale. Then you can combine them into one PDF with other apps or online tools.
  3. You could export from Figma as a 1x PDF and then use an online tool such as Compress PDF or I Love PDF to reduce the size.
Though I can see how supporting this natively would be useful for other users as well, so I’ve noted it for our Product team. I can’t guarantee anything on our end, but I can give it some visibility 🙂
Hope it helps!
agus_pelani
  • September 13, 2023
Its not solved, I have tried those points of your answer … so many takes time to get compression of FDF files 😅
georgezikos
I’ve noticed recently that Figma is exporting “optimized” PDF files, in that the file sizes are now much smaller. Am I the only one? I can’t find any information on this being a feature update!
  • 4890 replies
  • May 6, 2024
Jagruti_Jaykar
Most platforms, require pdf files to be under 5mb. take for example Linkedin Resume upload option. It cannot have even a 5.1 mb pdf. So When I exporting my resume from Figma, it kept exporting it at 7.2 mb. And online compression tools could not lower it below 5.1. Tried them all. What could you possibly to to a file that has only text and some color? This was frustrating. The tool should natively allow for some options.
Manon_n.k
  • August 27, 2024
Hi @dvaliao, My file containing 28 slides with 4 images, 1 vector image and some smiley images, exporting it to pdf creates a file of 19,5 MB. I just did a test in which I removed all images, so slides only contain text and a few shapes. Considering the content it still it still returns a file size of 15.4 mb… have to go back to using Powerpoint instead 😥
Cecilia_Marnero
same here, made my resume. 2 colors, one font, 3 vector icons and I still get 5 Mb even if I compress it’s compressed to 3,9 Mb so is not even worth it. it’s absurd.
Usama4
  • October 15, 2024
Hi, I really appreciate the subtle update!
I used to compress PDFs exported from Figma using online converters like ILOVEPDF. However, since this recent update, the PDFs I export from Figma still aren’t as compressed as I need them, so when I try to reduce their size using online tools, they often lose color.
This happened a bunch of times. And I don’t remember running into color loss before this update.
QWER AGENCY
  • 5 replies
  • March 17, 2025
When exporting PDF presentations from Figma, we often struggled with large file sizes (300-800 MB) that complicated sharing and collaboration. That's why we built our specialized compression tool at https://pdfcompressor.ru/ . Our service quickly and efficiently reduces the size of PDFs, preserving excellent visual quality and simplifying sharing via email or online.
Ethan Welner
Same with the resume issue. Figma jams so much meta data or context data into the basic file exporter that a literal empty artboard is still multiple MB. Figma really needs to fix that, its kinda absurd. I shouldn’t have to re-export the PDF out of something else to get it to work.
chrisjordon
Hey! If your Figma frame has no images but still exports as an 18 MB (megabyte) PDF, it’s likely due to effects like blurs, gradients, or complex vector layers being rasterized.
(Quick note: "MB" = megabytes, not to be confused with "Mb" [megabits] a common mix-up in file sizes vs. internet speeds!)
To shrink your PDF:
  • Simplify heavy effects (e.g., reduce blur intensity).
  • Flatten unnecessary vector layers.
  • Export slides in sections.
For more on file sizes (MB and GB, or even mb and mb), this might help:
MB vs GB: Difference Between Megabyte and Gigabyte
Hope that clears things up!
