Khagwal
May 6, 2021
Export and Save as SVG File
  • May 6, 2021
  • 4747 views
I am trying to export and save an SVG file.
I have tried exportAsync in following code which is returning svg code, but how i can save it as svg file.
let node = figma.currentPage.selection[0];
node.exportAsync({format: 'SVG'}).then(res => console.log(String.fromCharCode.apply(null, res))).catch(err => console.error(err));
figma.closePlugin();
Please help 🙂
Best answer by Khagwal
To export SVGs or PDFs, You can simply post message to UI’s window and save a respective SVG or PDF file using Blob. Hope this helps 🙌
Matt_Turnbull
July 8, 2021
Hey man, this might help you:
GitHub
Khagwal
KhagwalAuthorSolution
February 25, 2022
September 1, 2023
Hi,
I’m actually trying to do the same thing but I just need image and getting this error
Argument of type 'Uint8Array' is not assignable to parameter of type 'number[]'.
  Type 'Uint8Array' is missing the following properties from type 'number[]': pop, push, concat, shift, and 5 more.ts(2345)
