Error exporting from Figma and importing to Windev
Mari_Ducasse
Hi everyone,
Please advise, I’m trying to import a Figma design on Windev.
This error keeps popping up. The token has been entered and is valid.
Any tips or tricks on how to resolve this please?
Thanks in advance
Celine_
  • 3743 replies
  • August 20, 2024
Hey there!
I understand how this can be inconvenient. Windev is not something Figma supports, I think their support team will be in a better position to help you.
On my end, I find a guide from Windev that may help you:
PC SOFT online documentation
Other community folks may have some other tips or methods they can provide. I’ll leave the convo open in the meantime! 🙂
elaa.assist
Hi, i’m having the same issue, have you solved the problem?
Mari_Ducasse
Hi, make sure that your URL is correct.
It won’t work with https:/www.Figma.com/design/ , it needs to be https:/www.Figma.com/file/
Just replace “design” with “file”
Not sure whether that’s always the case, but it worked for us, so it’s worth giving it a try
Mari_Ducasse
Thanks for the feedback!
david.lievre
Yes, there is a recent change in Figma url and WINDEV can’t manage this correctly.
So you can change URL like @Mari_Ducasse say : change /design/ to /file/
You can also use document id directly :
Example : for https://www.figma.com/design/ZZZZZZZZZZZZZZZZZZZZZ/Untitles-
use only the ZZZZZZZZZZZZZZZZZZZZZ part in WINDEV import field
