Enable PDF Import on Figma
  • October 11, 2023
  • 8 replies
  • 9280 views
Wiebke1
Not beeing able to import PDF files into Figma is a real pain. Pleeeaaaase, this has to be fixed!
titanas
  • December 14, 2023
Hey there. You can import PDF on Figma (or FigJam) with a free plugin I made, called Super PDF.
Figma
Right now PDFs are imported as images and you can adjust the scale for higher quality. Soon improvements are coming to it.
You can also open and read (view) a PDF inside Figma or FigJam with Super PDF, as you’d normally do with a PDF viewer.
I hope that helps to solve the issue for now.
Theodora_Foien
+1 to this
Eric_Mercer
  • Figmate
  • July 16, 2024
Hi there! We currently support importing any generic PDF file, although import quality can vary and the content is typically processed as static images or text.
We also support importing Mural, Miro, and Lucid PDF files into FigJam, as well as importing Jamboard files directly via Google Drive. For these file sources, we’re able to import content with higher fidelity.
You can learn more about importing from each specific file source with these Help Center articles:
Let us know what you think!
Lan_Nguyen1
how do I import a pdf and just keep it as a PDF? I just want to be able to have an image of the pdf and extract pages from it (like I can in Miro). Right now, when I import into FigJam, it converts it to text/images and everything gets messed up.
Zeynep_Ugur
I am running into the same issue… Any luck so far?
Codia
  • September 21, 2024
We recently launched a brand-new product, Codia AI PDF: Import PDF/PowerPoint/Keynote to Figma, which can meet and solve your needs. If interested, you can give it a try.
https://www.figma.com/community/plugin/1395769067119787232/codia-ai-pdf-import-pdf-powerpoint-keynote-to-figma
Harness the power of advanced AI technology with AI PDF: Figma PDF Master, Online PDF Editor. This innovative Figma plugin transforms your static PDF files into stunning, fully editable Figma designs with unprecedented ease and precision.
FM_Medicina
am waiting too 🙃
Ardena_Gonzalez
Have you tried the plugin pdf.to.design? You can import PDFs as either images or editable frames, and they’re processed locally on your computer so your PDFs are always kept private.
