Embedding Figma Prototype into a Webflow Website
  • October 12, 2023
  • 2607 views
Hi All,
I am trying to embed a Figma Prototype into a Webflow created website and have it still be responsive at different breakpoints. All the support I have seen online is not addressing the issue for me.
Using the embed code from Figma and changing the iframe settings width and height to be 100%, the prototype still remains it’s fixed dimensions and does not scale with screensize. I have also tried containing it within a div block class and modifying the dimensions/scaling of the div block. Everything I have tried just results in it being cut off and cropped without any scaling to the actual prototype.
Any advice on how to get a an iframe to be responsive in Webflow would be greatly appreciated.
ksn
  • 1707 replies
  • October 23, 2023
Hey Isaac – are you using the Webflow plugin? https://www.figma.com/community/plugin/1164923964214525039/figma-to-webflow-html-css-and-website
I don’t know if I’ll be much help for this topic, but wanted to check on that first.
Telenkov
  • December 30, 2024
I have the same issue in 2025, almost 😅
Embed code was copied from Figma to Webflow’s embed section. Width and height changed to 100% to keep it responsive.
The result is a shrunk window where is only Figma UI elements visible, the whole prototype is somewhere else.
Looking forward to finding a solution.
