Developers seeing different font weight in Inspect panel than designers with editor access
Brooke_Corcos
Hi there! We ran into an issue where designers with editor access see one font weight in the inspect panel, but developers selecting the same text layer see a different font weight in the inspect panel. Any ideas regarding how or why this is happening, and which is correct?
Screenshots below (had to redact some info):
Developer view:
Editor view:
Thank you in advance for your help!
Does anyone also still have this issue? Because we do.
Amber_McLain
Yes it is occurring in our view as well. In a font we are using, our designers see 700 weight but in dev view it shows 600.
Carla_Januska
Hi, yes we see something similar.
I think it has to do with the font naming differences between font files for desktop (.otf) and server-side font files (.woff). Why font companies don’t reconcile all the weights with names is a mystery.
Angie_Meeker
Same here.
Matthew30
I am seeing this issue as well with most typefaces
Celine_
  • 3743 replies
  • April 15, 2024
Hi there! Thanks for flagging this. Is it happening with Museo Sans Font weight or any other fonts?
Please reach out to the support team directly with a copy of your file and indicates which Font you encounter that issue by filling this form here: https://help.figma.com/hc/en-us/requests/new Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so we can take a closer look. Thank you!
I have the same issue. The designer see 300 and 500 but in dev view i see 400 and 600…
Celine_
  • 3743 replies
  • June 11, 2024
Hey @Max_Undurraga , thank you for flagging this. Which font do you encounter this issue?
I see in our backend that we have a current long standing bug for Museo Sans font that our engineering team is aware of.
As said, can you please also reach out to the support team directly with a copy of your file and indicates which Font you encounter that issue here: https://help.figma.com/hc/en-us/requests/new This will help our technical specialists to investigate further your issue. Thank you!
Hello @Celine_Figma , sorry i forgot that, it was with Museo Sans as well
I will surely reach out the support team as well
Brooke_Corcos
@Celine_Figma Hi there! I’m the original poster, and we have been having the issue with Tempo Std. Is this a bug that the team is aware of or should I submit a request?
Celine_
  • 3743 replies
  • June 13, 2024
Hey @Brooke_Corcos , please also submit a request so the team can follow-up, thank you!
