Default corner smoothing
  • September 24, 2023
  • 529 views
Timothy_moose
Is there a way to set a default corner smoothing?
It takes multiple clicks to reach the corner smoothing dialog. The dialog itself is a slider with no quick way to select iOS-style smoothing other than fine-adjusting the slider to 60. Every. Time. Needless to say, it becomes a huge hassle when designing an iOS app. Hoping someone will tell me there’s a default setting I’ve missed.
Best answer by djv
Hey Timothy, thanks for reaching out!
This isn’t possible, but as a workaround, you can try selecting objects that need adjusting in bulk via “Select all…” quick actions.
To activate quick actions, select the object(s) on the canvas, then hit cmd + /, then type “Select all” and choose the command that’s most suitable for your case:
With object(s) selected, you can adjust corner smoothing all at once, but note that this will need to be repeated for each page of your file. Hope this helps!
  • 4941 replies
  • September 26, 2023
