Create setVariable prototype interaction via API
Brian1
I am trying to set up a Set Variable prototype connection with the API but when I copy the data structure for an actual “SET_VARIABLE” prototype reaction I get this error.
This is the connection I am setting up:
	let getVariableReaction = (newChar, varId) => {
		let newReaction = {
			type: "SET_VARIABLE",
			variableId: varId,
			variableValue: {
				resolvedType: "STRING",
				type: "EXPRESSION",
				value: {
					resolvedType: "STRING", // <-- this fixed my issue
					type: "EXPRESSION",
					value: {
						expressionArguments: [
								type: "VARIABLE_ALIAS",
								value: {
								type: "STRING",
								value: newChar
						expressionFunction: "ADDITION"
		return newReaction;
Am I missing something?? I copied it directly from what I see in Figma when I set the same interaction up in the UI.
This is what I’m copying from Figma when I look at a set variable interaction done in the UI.
SOLVED. Human error!
Needed to add resolvedType: 'STRING' in variableValue.value
Brian1
  • August 31, 2023
SOLVED.
Just needed to add resolvedType: 'STRING' to `variableValue.value
James_Yang
  • Figmate
  • 82 replies
  • September 14, 2023
Following up here, we just released official documentation and typings for advanced prototyping functionality in the plugin API: Version 1, Update 77 | Plugin API
