Components are not working
Luiz_Eduardo_Andreolla
In the past week, I’ve been experiencing an issue with my Figma files. We have a complex Design System with a specific file for icons. Even though the icons are published, I can’t use them in “Swap Instance” because most of them don’t appear. Strangely, they all show up in the sidebar, but they’re not visible in the “Swap Instance” feature.
Gayani_S
  • 2159 replies
  • June 21, 2024
Hey @Luiz_Eduardo_Andreolla, I can see that you’ve already filed a support ticket. I am going to share the outcome of the ticket here in the forum for community members experiencing similar issues.
If possible please share a screen recording with the support team. Please include the whole window, with the properties and layers panels in view and relevant layers expanded, and select any layers you’re having trouble with so we can check any relevant settings. Support use these videos to try and reproduce the issue in their own files and so showing all steps needed to reproduce the behavior is helpful.
Gayani
CamilaB
  • 28 replies
  • July 5, 2024
I’m having a similar problem, my icons have variables (ex: Chevron - up, down, left, right), and I can’t swap between the variables, it shows a list similar to what the parent component would have, and when I try to swap the component it shows the list but clicking does nothing. Detaching the component makes the thing work again but I use a design system, we’re not supposed to detach it.
Gayani_S
  • 2159 replies
  • July 10, 2024
Hey @CamilaB, thank you for reaching out! Let me reach out to the teams internally, I’ll get back to you as soon as I have more information on this.
Appreciate your patience in the meantime!
Gayani_S
  • 2159 replies
  • August 2, 2024
Hey @CamilaB, apologies for the delayed response!
Are you able to share a screen recording with us?
Are you seeing any warnings and misconfigured props (indicated by a (!) on the component set in the property panel), this prevents the component from publishing and updating as expected.
Can you try to publish a small update, like adding or editing the description, to all of the variants in the component set (not the top level set) at once to help the connected files update the set to the latest version of all states.
Also, please try to run the ‘Repair component connections’ command on an affected instance, and then ‘Regenerate all instances’.
Thanks in advance!
CamilaB
  • 28 replies
  • August 2, 2024
Hi Gayani, we had to recreate the component to make it work, I don’t have any recordings but I’ve been having issues with instances all the time. When I come across this problem again I will update this thread with information.
Gayani_S
  • 2159 replies
  • August 5, 2024
Hey @CamilaB, thank you for getting back to me!
Sorry to hear you’re having issues constantly with instances. I’d be helpful when you can share a screen recording with us. Please do reach out again if you should run into this issue in the future.
Thanks for the help!
CamilaB
  • 28 replies
  • September 5, 2024
I had a problem like this happen again, an instance within another instance just refuses to accept overrides. I have a video but the project can’t go public, is there somewhere I can sed this video to?
