I’ve been trying for a while to figure out if there’s a way to use variables to simplify the creation of interactions.
The component I have is the following:
I would like that when changing the name of the child component, it would apply to the interactions I’ve set in that component.
Is it possible to do something like that?
@Kaere_Alarcon You could apply a text property to all your “Text” within that component.
Then when you select an instance of that component, you’ll have a field that will allow you to change the text and that will change the text for the different states of that instance - default, hover, active.
