Component menu under resources should remain open
Hasim
Hi,
I use the Resource popup to select icons. I search for the icons and drag them to the design file. Every time the resource popup is closed after drag, I think it should open until I click somewhere on the design file, or I can close it with a close button. When I want to choose more than one icon, every time components load again, this is unnecessary.
ksn
  • 1737 replies
  • August 28, 2023
Thanks for the suggestion @Hasim – I thought there was a similar feature request on this that existed in the forum already, but I haven’t been able to locate it.
I went ahead and re-titled your topic and left it as a share feedback topic – that way others can find it better and add a +1 vote 😃
  • 4873 replies
  • August 28, 2023
Click on the “Dock to side” icon at the top right of the Resources modal or move the modal.
Hasim
  • 4 replies
  • August 28, 2023
Thank you for your suggestion, but this is not the same. Maybe there is a pin icon, and we can hold the popup open until we are done.
Hasim
  • 4 replies
  • August 28, 2023
Thank you. I think it will be useful.
  • 4873 replies
  • August 28, 2023
This is exactly what you want.
Hasim
  • 4 replies
  • August 28, 2023
Thank you. I tried it many times. But I don’t think this is necessary. Yes, it works, but I still think the pin button could be a better solution.
  • 4873 replies
  • August 28, 2023
Could you share details why the “Dock to side” feature doesn’t solve your issue?
Hasim
  • 4 replies
  • August 30, 2023
The change of location and size bothers me. There is no need for the panel to extend all the way down. With the floating window, I feel like it will disappear when I close it with the x button. It doesn’t feel like it will go back to its original position when I close it. Because this is what happens in many applications and we have a habitual feeling.
