'Clip Content' not working on bottom perimeter of frame
I have clip content checked/selected but it’s not clipping my contents on the bottom of the frame however it works on the sides.
Can anyone help me with this?
Best answer by Gleb
You can clearly see on the screenshots that the frame is larger than the gray background so it does clip content, you are just not dragging it outside of the frame border.
KennLucas
  • 221 replies
  • July 30, 2024
Can you post the file or a link to it please?
  • August 1, 2024
I’m having the exact same problem.
Have you discovered a solution?
  • 4706 replies
  • August 1, 2024
  • 7 replies
  • August 1, 2024
Hey Gleb,
You’re correct, I actually found this prior to anyone’s response. That was the first time that’s happen to me where somehow the frame got shortened.
Thanks for your reply!
  • 7 replies
  • August 1, 2024
Already solved but thanks for this suggestion and I’ll remember to do that next time.
  • 7 replies
  • August 1, 2024
have you read the comments and are you still having this issue? If you look in the first screenshot you’ll see that the frame got shortened somehow (see largest blue outline and look towards the bottom) so I needed to extend the object (grey fill of the frame) down to the blue border and then it reflected the clipped content.
  • 7 replies
  • August 12, 2024
Yes I did. I actually figured it out before anyone commented but the first comment still helped with context.
